e5 code
Dryer quit working got an E5 code.Any suggestions. Thanks in advance!
Hello Canes. There is no E5 error code listed on the tech sheet. Can you check and make sure it is an E5 error code? If the code is tS, then you have a bad thermistor and will need to replace it. Also, make sure the venting system is clear from any blockages. Hope this helps.
[part]AP4045224[/part]
Bulkhead parts replacement parts for MAYTAG NED7200TW10 29" ELECTRIC DRYER | AppliancePartsPros.com
