electonic control panel for GE washer
My start button is not working. The replacement part GE sent me wh12x1076 has a 4 dial face my washer has on only 2 dials. The part fits properly. The problem is that it continues to blink. How do I get it to work. I have tried holding down the start button and unplugging then plugging back up the washer
That should be WH12X10176. You must transfer the model select plug from the old board to the new one. It is the plug with one or two jumper wires on it. The control works with different washer models, the jumper tells the control which model you have.
Eric
Thank you Eric
