I have replaced both roller assemblies, and found a screw fell out of the heater housing which I replaced, but the squeal is just as load. is it the idler pulley or the bearings? What parts will I need?
Here is the parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE9806AYW
Open it up and check the following for wear and/or slop
Idler wheel and shaft
Front glides Item 30 in Tumbler section (Kit-bearing)
Spin the motor to be sure the bearings are OK and that the blower is not rubbing on the housing.
Here is a good link - check out 25 & 26
http://www.applianceaid.com/maytag-dryers.html
