My Gibson GER331CS0 electric dryer stopped producing heat last weekend. Following the great info on this site I checking many possible causes. Eventually, I took the dryer apart and found the heating element had broken. Both ends appeared to have remained in the clear of ground.
I purchased and installed a new element from AppliancePartsPro and put the dryer back together.
It still runs but produces no heat.
The high limit thermostat has continuity (goes to element).
The control thermostat has continuity between two terminals and 28 kohms between the other two terminals which matches the schematic (goes to element).
The thermal limiter has continuity (goes to motor?)
I went over the control logic and tested the controls. Everything produced the correct answers.
The only other possibility I see is the switch that appears to be in the motor that goes to the heating element. Any way to test it? What are the chances it went bad along with the element?
Any way to test it?
One way is to unplug the unit then short the switch wires together.
Be sure to tape them etc. so that they cannot short to anything else or get caught in moving parts.
Then plug it in and give it a try.
The above is just for testing do not leave the unit like this.
[COLOR="Blue"]
What are the chances it went bad along with the element?[/COLOR]
It is possible if the element was pulling too much current before it blew and took out the switch.
The first thing I would check is the power to/at the unit.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
denman said:
Upper felt seal worn out from taking it apart several times? Or bearing kit no good?
I cannot say without being there.
Did you clean out and then re-grease the rear support bearing using high temperature grease?
Be very careful if you try to grease the rear support bearing. Many of these are sealed bearings and will not accept grease. A grease that melts and drops down into the area of the motor or other sections can be a real mess if it does not cause a fire.
