electric oven - F-3 error code
After we got the F-3 error code several times and the oven finally would not work at all, we replaced the oven sensor. This did not solve the problem. After further investigation, we found that the oven fan switch wasn’t working so we replaced that. We tried using the oven again and it worked fine for about an hour. When we opened the door to check the food, we immediately got the F-3 error code again and now the oven won’t work at all again. As soon as it starts to heat the F-3 code comes up and it starts beeping. What the heck is going on??? Help!!!
