Electric Oven Issue - Worth Repair??
Hello,
I have an approximately 2.5 year old Maytag electric MER5755QAW. Two days ago my wife was baking and she gave quite a yelp when she saw a bright flash from the base of the oven and heard a quick buzzing humm sound. The oven’s bake and broil elements no longer work. The cooktop, clock, control panel, and oven light all operate "normally".
I have tried to read several posts to try and figure out problem. It would be nice if just elements need to be replaced, but why would both not work? This leads me to think maybe problem is not elements, and maybe problem is thermal fuse??
My question is what do you think problem is and is it worth fixing? I would also be curious what I should expect to pay to have fixed if it is not something I can handle myself?
Thanks,
David:confused:
Hi David,
Visually inspect both heating elements for any visible damages.
Turn the power to range off.
Pull the range, remove the back cover and check all wires.
Remove at least one wire from the Broil and the Bake elements terminals and check the elements for continuity.
If there is nothing wrong then the control board (aka clock) has to be replaced.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – [URL="http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4810-how-check-continuity-ohmmeter.html).
I believe the 2.5 years old range is worth to fix but your decision should be based on condition of the unit.
P.S. There are no fuses.
David,
The Bake heating element has to be replaced. No doubt about it.
  • The part number for the Bake heating element is AP3860007
To check for "short on ground" you have to put one of the test probes on testing part terminal and touch with the second test probe any metal body of this part.
All wires on the picture looks good.
Gene,
Thanks for the reply. I will go ahead and order the bake element. One question before I do, why would the broil element not come on? Is this just due to the bake elements failure?
Thanks,
David
David,
Let’s do one thing at a time. Replace the Bake element and post the result.
Ok, will do. Thanks.
David,
The clock is not too difficult to replace yourself. Remove the rear control panel cover to access the clock. Remove one wire at a time from the old clock and connect to the new one.
Nobody can tell you what else could be wrong with your range, but it is not very old and a new range will cost you much more than 160 bucks to fix this one.
It probably will work without this indicator light. At least you can try. Insulate all wires, using an electric tape and turn it on. This light is probably gone.
The drive belt came off causing the tumble action or spin not to work.
Purchased a new belt from a local dealer. Compared it to the old one to make sure I had the correct belt.
The problem I’m having is installing the belt. You can not just slip it on. The belt won’t stretch enough to get it on the pullys. I do not see any tension adjustment device.
Please advise.
Ron
Ron,
Check if both pulleys are aligned properly and the drum pulley is not playing in and out. If not then the rear drum bearing has gone bad. This is one of the most common cause for the drive belt to come off.
What is the part number of the belt you bought? Is this the original part? That could be a problem too because the original belt is elastic and designed to "give" enough for installation.
The correct part number for the belt is [AP2108082](http://www.appliancepartspros.com/part_details.aspx?part_id=2108082&pn_=134051000"]134051000[/URL] which is Appliance Parts Pros part number [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=2108082&pn_=134051000)
Here are the break down diagrams and the parts list for the Gibson washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=250719&&model_id=118788
This was a great thread. I had the same problem last week; while cooking dinner I heard a buzz, pop from the stove and the lights flickered in the house. I checked the stove and it was no longer on.
After Reading this thread. I unplugged the stove!
First I replaced the bottom element by removing the racks and the two screws on the bottom cover plate at the back of the inside the oven. Next I removed the cover plate by lifting up on the sides. Once removed, the burner was clearly blown so I bought a new burner at the local Maytag store and installed it in about 20 mins.
However I still had no heat from the top or bottom element.
I then ordered a new control unit - Part Number 74009211
I found the control unit for various prices on the internet from 115 US to 225 CAD.
www.**************************.com seemed to be the cheapest, but I actually ordered it from a friend of a friend direct from the manufactor for the employee price of 88 CAD with tax and shipping.
Unscrewed the old control unit by removing the top cover at the back of the oven (use 1/4 socket) and then 4 phillips screws holding the unit in. Screwed the new unit in and then removed each of the wires one at time and pluging them into the new unit that was already attached.
Put the cover plate back on and then plugged the stove back in and everything was working fine.
Thanks again for previous threads! Saved myself a bundle. Sears wanted 80 CAD just to come out and diagnosis the problem before any parts and labour.
This was an easy job, even for a novice.
ibdavid said:
Hello,
Thanks,
David:confused:
I have had the exact same issue with the exact same model, only black in color. I am wondering if you ever got a response or figured out. We are looking at replacing the circuit board and are wondering if it is worth it. What would you recommend we do?
Thank you!
Well thanks to Gene I am still using my now 8 year old MER5755QAW. Recently one side of the door handle appeared to be loose. I started to take the door apart to investigate. I took off the top door trim piece and was able to remove the outer door glass. I then encountered the handle brackets (#14 http://www.appliancepartspros.com/04-door-drawer-parts-for-maytag-mer5755qaw.html )which attach to the inner door behind the outer glass and use a screw that comes from behind and attaches the handle to the top trim piece. Upon investigating the hole in which the screw goes into the handle I discovered it was cracked. Several attempts with JB weld and other methods and unfortunately it looks like I will need to get a new handle. Worse the outer glass that I had removed successfully later shattered.
Ok so all that background to get to my problem. Although it is not logical I cannot figure out how to re-install the outer door glass. If I attach the handle brackets first I cannot put the glass in the door. I thought at first i could place the top edge of the glass into the groove for it on the underside of the top trim piece of the door and then "swing" the glass down to the bottom grooves in the lower part of the door. But it does not fit.
Of course if I put the glass in first then I cannot attach the handle brackets to the oven door. Specifically the screw from behind into the handle as it goes through the top trim piece and you cant put this piece on and later put the glass in.
Did I just somehow remove the outer door glass initially in the wrong way? As I cannot figure out how to put it back in. I looked at various videos on replacing the outer glass door but none of the ovens shown had these brackets.
Do i take one of the side pieces off the door ( #17 or 18) and slide the glass in from the side??
Also a side question does the outer door glass go in with the thermal tape at the top?
Hello David,
You have to remove the door from the oven first. Did you do it?
I hope the attached instructions will help.
My now 13 year old range has been working the past 10 years due to Gene’s advice and help.
Yesterday the range made a buzzing sound when attempting preheat.It never made it past 205. The cook top works, interior light works, and broiler element also works.
I tried to pull the bottom cover to inspect bake element and one screw is stripped. Will try ez out or dremel tonight.
Knowing the history is it more likely the clock / brain will also be bad again? Unlike last time (details above) the broiler element is still working.
