electric oven
wiring burnt out at the lower element. repaired the connection but oven doesn’t turn off or thermosat doesn’t turn off or regulate the temperture. also notice burnt wire at the back base of the thermostat
I have ordered a washer timer switch from this website. Can you give me instructions on how to remove the old one. The Sears repair tech wanted over
$300 for this repair.
Thank you
