The problem could be the control panel (keypad) or the electronic control (timer).
The usual way to troubleshoot this is to check the keypad outputs and if they are OK then replace the timer. But I cannot find info on the actual keypad outputs so unless you have some experience troubleshooting keypads this will not be an option.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
If this does nothing then pretty well all you can do is take a gamble on one of the parts.
