electric range
my kenmore electric range when i go to use the bake on the oven the element at the bottom does not get hot all the time what part is bad is it the element please let me know thanks david
The model number you posted is incomplete. Verify and repost it.
hi gene my kenmore electric range model # 790.95889302 and the serial # is vf40944454
Hi David,
Pull the range out of the wall and remove the back cover. Remove the wires from the Bake heating element and check the heating element for continuity.
If it’s open then replace the Bake heating element.
If there is nothing wrong and the wires for this element are good then replace the Electronic Oven Control (aka a clock).
Do both Broil and Bake do not heat?
The broiler does work. There is an ON indicator that comes on when the Broiler
is activated that also comes on when the self-cleaning is taking place. That is probably normal. Now that ON light also comes on when I try to turn on the oven, but the oven does not heat.
thanks.
Pull the range out of the wall. Remove the rear cover and check the wires to the Bake heating element. Remove the wires from the Bake element terminals and check the element for continuity. Replace the element if it’s open.
If the element is good then replace the control board.
My machine is spinning but I am having to run that cycle 3 times to get dry enough to put in dryer. Any help appreciated!
The clothes will come out wet for one of two reasons. Either the spin is not fast enough or something is preventing the water from completely draining.
Check the pump and drain hoses for an obstruction. If you need more asisstance let us know what you find out from looking at the pump and drains and post a complete model number.
