Bought new heating element about 3 months ago. It worked great.
Now - no heat. It runs no problem, just doesn’t heat.
After the heat went out, it came back the next day (but not as hot as usual), and today there is nothing at all.
I would start by checking the heating element with a meter.
Check the heating coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and touched the case. This could cause what you describe and now the element is burned out.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
I’ve determined that it is the timer. I even opened it up, and it is nicely burned out in one corner. Do you know why this happens? I mean it’s only copper connectors inside; why would it burn out all of a sudden?
Do you know if it would be possible to just replace the burned out metal parts on the inside?
It probably did not burnout all of a sudden, it probably took some time.
What can happen is that the contacts can get dirty/pit over time. This pitting causes there to be some resistance between the contacts. When current passes through the contacts, heat is generated. This further degrades the contacts and so on and so on till the contacts fail.
I do not know of ant place that sell the timer’s inmternal parts.
