I replaced the electrical control unit. After plugging in, all the LED’s light up and blink. How do I reset the electronics?
GE does not allow anyone outside of GE to have access to its tech info so I do not know if there is a reset procedure.
There should be technical information inside the console there. If that does not tell you, or if the info is missing I can only suggest you contact GE and see if they can hellp you.
Sorry not to be more helplful. Good luck.
[SIZE=3]I am assuming you replace the control panel correct?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]If so on the old control you have a plug with just a jumper wire. Often people will leave this plug off because the wires don’t connect to anything on the washer. This is the model select plug and if it is not installed on the new control all it will do is blink the lights. Hope this helps! [/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html
— Begin quote from applianceman;127020
I did replace the control panel, and you are absolutely right. Thanks!
