The receptors on the replacement relay (pn 2188830) for the compressor relay are not the same size as the old one. Do I need to replace the connectors or buy additional wire with corect size connectors? Also, I had three clearly marked connections (white, blue and red wires) on the old device, but I see only two on the replacement device–what did I miss.
The start device with the part number 8201786, which is APP [part]AP3885081[/part]
is the correct part for your refrigerator. It comes with the installation instructions, so you would be able to choose the right piece for your compressor.
