The control panel is completely dead. No clock, no beeping on any of the buttons…if I replace the control board will this usually resolve this problem or should I investigate other possibilities?:rolleyes:
HI.
If you have 240VAC to the range and surface units are working replace the control board
[WB27X5572](https://www.appliancepartspros.com/search.aspx?p=WB27X5572)
Here are the breakdown diagrams and http://www.appliancepartspros.com/cooktop-control-panel-parts-for-ge-jbp48wy1.html
Post the results.
Simon.
