Wife noticed center partition of this dbl dr frig very hot. Tech came out and said the Electronic Control was not functioning properly and caused the fan to run at a slow speed therfore not keeping the (whats ever in there) cool. He said I needed the part #2307028 replaced (Electronic Control).
I think I see where the part is housed. Can you tell me if it is something that can be replaced by me. I am pretty handy about putting things back together, but does anything have to be re-set with some type of metering before the new board works properly.
It looks like the board is housed in a gray plastic box. If it is a simple replacement, can you give me instructions on how to proceed to get to where the board is housed? Your company has the part and I can save about $220.00 by doing it myself.
Your model # doesn’t work, please check.
Measure freezer and fridge temperatures, and post.
Is the middle trim between freezer and fridg sections the item getting hot, if so you probably have a bad condenser fan or clogged condenser coils all in the back behind the panel.
Did you ever figure out what was wrong, cause I am having the exact same problems as you.
— Begin quote from billiardlo;11589
My Kitcheaid refrigerator MODEL # KSCS25INSS00
SERIAL # SR2433331 IS ALSO NOT WORKING PROPERLY.
I checked the compressor fan and it does not have power (115v) going to it.
Where does the power come from and what is the most likely problem?
The frame around the doors are extremely hot.
Additionally, I used to hear a "vacuum noise" when I closed the freezer door, but no more, since this is other problem arose. Could it be this electronic control & where is it found on/in the refrigerator?
I am having trouble with the same model (KSCS25INSS00) and can tell you for certain it does not use a 115V motor. It uses a DC motor.
I replaced both the condenser fan motor and the inverter board and am still having trouble. A Whirlpool authorized service tech recommended I replace the inverter board when a new fan did not fix the problem. The condenser has been cleaned.
The fridge works fine when I leave a small house fan blowing on the compressor but am unable to figure out a permanent fix.
I replaced the control board as mentioned above the condenser u it and thatfixed theproblem. However the location of that board on top of the condenser will keep high heat on the board and increase the rateof failure.
I’m not sure if you havethe same set up or not. But that was my fix.
