Electronic Problems
My dishwasher failed. We have had a recent thunder storm. Now, I can only get the air dry button to light and the 2 min cycle to run by pushing cancel. Is it the electronic control board or the push button front panel or both? Or maybe something simpler? Thanks for help.
Today I disassembled and reassembled board and panel, wiggled everything. Now it is washing dishes. But for how long? I saw nothing even questionable. Parts have not arrived yet. ??? Bonac
I am tirering of this. This morning it wouldn’t work. I replaced the control panel this time. It works now. What next?
My GE frontloader is acting up. It pumps water out, but doesn’t spin. I have cleaned all of the change/baubles from the hose, no difference.Checked the pump, and nothing is in the way. Removed the belt, set the timer to Regular wash, started it, the motor doesn’t turn. checked the speed control with a meter, it seems to be ok. How do you check the door lock switch to see if it’s out? I know how to remove it, but don’t know how to check it, or the timer switch either, which seem to be the only two things left. Any other ideas?
Also, the tech sheet that was in the washer is falling apart, and its hard to read. can you get another copy of it somewhere?
Rhonda
sounds like what is wrong w/ our GE Frontloader. Noticed your date is about 6 weeks old. did you ever find out what was wrong w/ it? Ours did the same thing last night. It will spin when we first start the cycle, but that’s it.
