elg444
How do I remove the Front Cover Assembly Part # AP3135525 to get to the ice chute? Do you pry it off?
Start at the bottom with a putty knife, and work around clockwise. Tom http://www.applianceeducator.com
Thank you the cover has been removed.
The problem has been that the ice door does not shut sometimes. Should I replace the spring AP3953917.
