Elvira
I have the same problem with our whirlpool double oven. While in the middle of baking bread the control panel went blank and the oven no longer functional. I left the oven alone and in 15-30 minutes the digital clock reappears with the Code E6 F2. When I push turned off the code disappears. When I tried to turn the oven on again it worked and then the screen went blank again after a few
minutes working & then the oven didn’t heat and the screen went blank again. s it the control panel? Please help.
I repeated this the next day and it did the same thing.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=RBD305PDQ14
See the attachment for the tech sheet
This is difficult to trouble shoot as the error is related to the control panel keypad. Also it may be related to the unit heating up and causing a bad connection.
I would try the following first as it may just be a bad connection.
If that does nothing I would replace the control board.
This is a gamble but it is the most likely cause.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
