Received Error code 62 and need assistance to order correct control panel for this model front loading washer.Thank you!
I don’t see an explanation for that error code in the generic service manual for this model, so look inside the lower service panel and you should see tech notes which will explain the error code to you and tell you how to fix the problem.
Good luck!
I realize this error is not listed.From what I have read in similar posts, blinking lights, beeping, the control panel appears to be the problem. I am seeking the correct part for my model. Thanks
Ok good, I think you are correct and if you buy the control board from this site you can return it if it does not fix the problem. To make certain you get the right part I suggest you call in the order and have both your model number and your serial number available to give to the person taking the order.
