error code 1F
In previous post Jeremy wrote and you replied the following.
Error code ER IF and has neither ice nor water. Otherwise refrigerator works well. I have been told something is wrong with the ice fan or control board, is this right? Please advise.
Jeremy for Model Number LG LFX31925ST/00
ANSWER Hello Jeremy, There is a service bulletin out on your model number pertaining to the complaint you have. For serial range between 103KR****** and 301KR******, Replace Main PCB and Grille Fan Assemblies. As per the bulletin, the part number for the main board you need to put in is (AP5671401) and the fan & grill assembly to be installed is (AP5672259).
Answered by AppliancePartsPros.com | Thursday, July 25, 2013
I have contacted LG and they said there is no service bulletin for this. Do you have any more information I could use, a copy of bulletin or a bulletin number. My serial number is 210kr******* so it would fall into the group.
Any help would be appreciated. Mine is still under extended warranty and would like to get if fix before that expires.
