For the last 6 months we kept getting error code F10 now and again. I read up on this and did the following. Checked continuity at room temp of the oven heat probe. It was normal as per the specs that I saw. It was around 1100. I did the same on the wiring harness. Same result. So I went and bought and installed a new Control Board. Now it is doing it again within a week of board install. This range is about 3 years old and it is the second board replacement. First one went in the first 3 months. Should I replace the probe even though it shows that it is to spec? Any other ideas? Thanks
Related topics
Error Code F10 | 1 | 1123 | July 11, 2016 | |
Frigidaire Range F10 Error | 6 | 4856 | August 14, 2012 | |
Frigidaire F10 -a couple questions! | 1 | 1114 | November 30, 2013 | |
Frigidare Issues | 3 | 1891 | July 6, 2011 | |
Is my control board the problem | 1 | 994 | November 16, 2011 |
