Got the error code F30 and received a fast response. Thanks. I forgot to mention that I am unable to set clock. Does this indicate that I need to replace something in addition to the oven sensor probe if defective?
Hi.
Don’t just replace the sensor, first check it’s resistance - about 1100 ohm at room temp.
You may need to replace the touch panel, but first clean the flex ribbon edge with isopropyl alcohol.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5159581
Simon.
— Begin quote from Simon / APP Team;770375
Hi.
Here are the breakdown diagrams and Replacement parts for Frigidaire GLES389FSB Frigidaire/electric Range | AppliancePartsPros.com
Simon.
By touch panel do you mean part#20 clock?
Hi.
The touch panel is #19.
Simon.
According to the diagram part #19 is listed as [AP4359887](http://www.appliancepartspros.com/Appliance-Parts/frigidaire-panel-back-guard-item-number-ap4359887.aspx"]PANEL-BACK GUARD[/URL]
Item Number: [URL="http://www.appliancepartspros.com/Appliance-Parts/frigidaire-panel-back-guard-item-number-ap4359887.aspx) Are you sure I might have to replace this?
Hi.
The control panel is #19 AP3893195. You are talking about #19A.
Simon.
