My Frigidairre stove is flashing Error F10 and beeps when I try baking. It runs fine on Broil. I cleared the error and beeping stopped but when I re-started it gave the same error. What does that mean? Can I fix it or I need to call a service agent?
"F10" means "Runaway temperature". If it does not show up on Broil then the problem most likely is a bad control board (aka an EOC or clock/timer).
- The part number for the control board is AP3776874
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=899181&&model_id=5159116
