estate electric dryer
my dryer originally would not stop at the off area, it would then continue on thru several cycles until you stopped it. Now it will not run at all. Is this the timer? We already tried the thermal switch
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=eed4400wq0
Here is the wiring diagram
http://forum.appliancepartspros.com/attachments/dryer-repair/6306d1375089579-estate-model-dryer-not-heating-properly-eed4400.pdf[U][U][/U][/U]
If it has an interior light does that work?
If not it is probably an electrical problem.
It is the L1 to Neutral side that runs the motor and light.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If OK
Check the BK to B contacts on the timer with a meter. Should be 0 ohms in any run mode.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
