Estate washer fill but won't start
My estate washing machine will fill with water but will not start or agitate. I’ve checked the lid switch and it checked out good. I’m at a loss, I have basic knowledge of electricity but I’m at a loss. any help would be appriciated
Hi,
Will it drain the water out and spin?
It will spin if you set it straight to spin cycle and turn it on. The drain opens.
If the motor is just dead during the agitation cycle it could be a bad timer or a bad connection on the wire harness plug at the motor.
A less likely event would be a bad water level switch, but if the water shuts off by itself chance are it’s fine.
thx. I’m going to replace the timer and hopefully that will fix the problem
Your welcome, let me know if that fixes it for you.
Happy Holidays
