Evaporator keeps iceing up
Hi, i am working on a GE refrigerator with bottom freezer. Found coil iced up. evap fan running, checked element and limit switch both checked out fine. Limit switch opens warm and closes cold, heating element around 30 ohms. Put it back together 4 days later iced up again. Also is there a way to manually put in in harvest. Tech sheet did not have the sequence info.
Jerry
Do the test that Joe/app team suggested in the response above "iced evaporator".
