My old top and bottom fridge completely died while I was on vacation, so "intelligent" me picked up this 2 year old Hotpoint side by side from a guy on Craigslist. Sigh.
He had it plugged in and running, and it seemed cold, so I went ahead and bought it. Got it home, and the fun began.
It gets cold, but the freezer does not freeze, even with both sides on 9 (coldest). Stuck my thermapen in the freezer, got 38 degrees, and 46 in the fridge. No unusual sounds, no clicking, etc.
Last night, I pulled the unit out. Took the access panel off the back of the fridge, vacuumed out a ton of dust and fuzz from around the big motor there (which seems to be running fine).
Opened the freezer, took the false back out. Fan inside the freezer is running fine. Coils appear to be clean. Light frost on the bottom half of the coils, little bit heavier at the very bottom. Very slight layer of slushy ice just below the coils, around the drain area. Poured a little water into the drain just to verify that it did, indeed, drain out (it did).
Reassembled everything, set both sides to 8, went to bed.
This morning, no freezing. Temp reads 36.4 degrees in the freezer side. I get 36.8 in the top of the fridge, 44 in the bottom.
Just for grins, I set the controls to 5 and went to work… but I doubt that I’m lucky enough for it to be something silly like a backwards setting on those knobs.
What are my next steps? From the reading I’ve done, I’m afraid that I’m out of the free/cheap repair possibilities.
Thanks so much for your help.
