F03 fault code ? on integrated oven
Hi I have a fault code on my oven ( F03) I phoned Whirlpool direct and was told that it was the control unit.So I replaced this with a new one but the fault code is still showing:mad: .Can anyone help :confused: Please
Thanks in advance.
Chris
Chris,
"F3" error code usually signals a problem with an oven sensor. If you need more accurate advice then post the complete model number of the oven.
