Maytag Range Oven (bake / broil / clean) will not work - I just get a F3 error code and a beeping -
I checked all the connection on the circuit board to make sure they were tight and a visual inspection -
Is this the circuit board ?
No actually that code comes up as a bad sensor. Your part # is 12001656. Tom http://www.applianceeducator.com/parts.htm
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MER5730AAA
Sensor is Item 5 in Section 4.
Here is a good link on how to check it.
http://www.applianceaid.com/elecrange.html
Check out 7,8, 20 and 21.
If the sensor checks out OK then odds are that the control board has a problem.
This may also come in handy
http://appliancedigest.com/index.php?/files/file/477-16010161-maytag-gas-and-electric-range-service-manual/
You have to join the site to download the manual but it is free and this is a very good site for manuals and other info for the appliance repair DIYer.
Thanks Tom…
Glad to help!!! Sometimes, too many cooks spoil the broth!!! Tom
