F3 Error Code - Broiler Element
HELP!!! Received F3 error code while baking. Baking element shut off by itself and broiler element came on and would not shut off until breaker was flipped off. As soon as breaker was turned on, broiler came on again. Researched and replaced heat sensor which seemed to correct the problem, BUT… now there is what looks to be the cooktop element that stays on all the time. The cooktop itself is not hot and does work when turned on to use, but there is an orange-glowing element right under the cooktop that does not go off. This scares me that it’s going to cause a fire, etc. Can someone please enlighten us what this might be. Never saw this orange-glowing element on before we replaced the heat sensor.:confused:
