F3 Error Code
RCA electric stove model no. L3S340GL0. Oven quit working, flashes F3 code only, push reset button. Unhooked power attempting to reset stove. Replaced oven tempurature sensor, electronic oven control assembly. Still getting F3 code. Any suggestions?
Hi Eva,
Pull the range, remove the rear cover and check the sensor wire harness from the sensor plug to the control board.
Eliminate the sensor plug and hardwire it, using the high temperature porcelain wire nuts (AP3440522).
Check the sensor plug at the control board for tight connection.
