falt code "dL"
I have a Whirlpool Cabrio automatic washer. Last year I had to replace the control panel. Now the "dL" code keeps appearing (door lid cannot lock). I have done what the troubleshooting guide tells me to do but nothing is working. What do I do now? Is it something in the control panel again or something else? Can someone tell me what needs to be done.
If the is not locking then check the wiring to the door lock assembly. If it is ok the likely problem is with the door lock assembly.
If the door is locking then either the motor control board or the central control board is not acknowledging that it is locked. Since you recently replaced the central control unit the more likely problem is the motor control board, but with electronic controls and troubleshooting you can never be sure.
This service manual will show you how to do some checking, but in the end you may have to go on faith and hope.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
