fan motor replacement
I ordered a fan motor only replacement part #AP4140906 and two new gromments, instead of the complete fan motor and housing, for my 2004 Samsung model RS2630SH. My ? is how detailed of a job this is gonna be or just a simple repacement into the original housng to restore this compressor componets cooling gem.
Thanks,
Frank
— Begin quote from buckit;362562
Thanks,
Frank
Frank,
Not that major a repair,
The best way, is to remove the whole assembly,
Be careful, there’s a lot of sharp edges,
And that housing is a "snap" fit into the base of the compartment.
[LEFT]The condenser Fan is located in the middle of
machine compartment. It cools down the subcondenser
and the compressor.
  1. Lift up the rib under the motor support.[/LEFT]
  2. Pull the support motor.
Not a lot if information from the service manual.
Good Luck,
Thanks,
Frank
Thanks Joe, your advise is what I was hoping to hear.
— Begin quote from buckit;362588
Our pleasure to help,
Drop us a line when you’re done, and let us know how you did.
Joe M.
Thanks again Joe the new motor was a breeze to replace as you had stated in your first reply, The fan blade was the only problem I had and after removing the spring clip and putting a squirt of wd-40 on the shaft it finally slid off without breaking. The new Samsung fridge fan motor is now running like the new one it is. Thanks so much
Frank(buckit):slight_smile: :slight_smile: :slight_smile:
— Begin quote from buckit;368777
Joe M.
Frank,
I had a feeling you’d do fine,
We’re glad you’re up and running.
It was a pleasure to help.
Good Luck,
