Fault code F09
Replaced inlet valve on back of machine for hot and cold water, replaced drain pump and black ball and bottom tub hose. Just started using machine again, and it is fine but then the 09 code appears, and have to reset to start again, upon starting again, it dumps the softener into the machine and then finishes washing.
Checked the drain hose, good, drain pump filter, clean(and brand new), supply hoses, no kinks, what else could it be?
help,
Jim
