filling with water
washer will not stop filling with water
Will it stop if you turn it off or unplug it. If not the water inlet valve is stuck open. It’s where the water supply enters the washer on the back.
If it does stop then the pressure switch has a problem. The tube or the switch itself. Use your model number to find diagrams and parts.
