My washer filled & agitated, then nothing else. No hum buzz or any thing. When I turn to rinse, it agitates, but it will not spin, or pump water. Thanks for any help.
kellconn
kellconn
Hello . It sounds like you have a bad lid switch.
[part]AP3100001[/part]
this is where I would start and is your most likely problem.
[model]11026912691[/model]
Thanks Gary. You were right, it was the lid switch. I wired the wires together and it worked great. Replaced switch. Thanks again kellconn.
