fills with water but will not wash
my dishwasher will fill with water shut down goes thru the cycles and not wash at the end it drains what little water that is left in it
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5540880&diagram_id=29059584#d29059584
Here is the tech sheet.
http://manuals.frigidaire.com/prodinfo_pdf/Kinston/154737301.pdf
Check to see if the wash motor is getting 120 volts when it should be washing.
If it is and is not running or making any noise then it is toast.
If there is no voltage then the control board is probably shot.
You could try the water/service test.
If the motor runs then the board would be at the top of the list.
