First things First... how to remove front panell
How do I remove the front panel on my kitchenaid washer? The washer pumps water out but will not spin or agitate. I heard something snap I believe.
before you remove anything lean washer back and look under it for broken pieces of plastic if you see anything its a coupler
There are no broken pices under the wsher. I just leaned it back and checked. Anything else??
Remove the front panel. it’s easier than leaning the machine back. Chances are it’s the coupler though even if you can’t see any pieces.
to remove the front panel, use a putty knife about 2 inches from the corners between the top and front panel. Raise the top up and remove the front panel.
Nat
glad i could help. if you can take it apart you can put it back together.
Push the motor down with one hand while pushing the bottom clip up with another.
Harleygurl, you go girl. This person gave you excellent instructions. I used similar and my 17 year old son fixed the coupler in 20 minutes
How hard is it to replace a broken ceramic top?
