Fisher Paykel Washer Malfunctioning
In last three loads, Fisher Paykel Washer has developed a loud humming/growling noise first with the "shower" feature. It has now spread to the drain and rinse cycles. The machine will work–it agitates and spins correctly. However, the noise seems to be worsening. Any suggestions will be much appreciated.
If you believe any part requires replacement, we will need a schematic of the washer in order to repair it. Any suggestions?
Many thanks!
