Fixed leaky tub now clutch is clacking ????
I just fixed the leaky tub with the seal kit :slight_smile: for it and now the clutch is clacking loudly:eek: :mad: . Its slipping:mad: , I thought that I tightened the tub down to tight but it still clacked when I retook everything out and ran it without the tub on it. Whats wrong???:mad:
jkl
the washer does not spin well:( I did not over tighten the large hex nut. If I manually spin itclockwise its kinda firm but the other way its finda freeโ€ฆ what do you think:confused: :confused:
jkl
Pull the front panel and remove the belt. Turn the tranny pulley in spin direction.
If the spin basket will not turn=bad tranny.
