The refrigerator side is freezing up and I have the temp set at its lowest position. Curiously, the ice maker quit working around the same time. Freezer otherwise seems to be working correctly. Any way to check t-stat with multimeter? Does the control unit control both refrig temp and ice maker?
Another unrelated issue is the ice dispenser runs non-stop. I had to unplug the front switches to get it to stop. Bad switch board?
The ice maker quit and I think I found the problem. When the fridge side froze, the coil of water line froze not letting water get to the maker.
As for the ice dispenser, I already changed the power board so the micro switch board is next… maybe. With this amount of money it maybe time for a new fridge. This model has really not impressed me.
