Foreign object stuck between drums
I have a foreign object (ie coin or screw) stuck between the two drums. I cannot determine how to remove the little panels inside the drum to open up a space to try to remove this object. Anyone having any suggestions other than having the drums completely removed? This foreign object is jamming my drums and has broken the belt. It must be removed.
You can try to access the tub through the sump. Remove the lower panel and locate the sump hose which runs from the back of the drain pump in the middle to the tub. It is held in place with a clamp that can be removed so you can open up the tub. Have towels handy as any water in the sump will be all over very quickly. There is also a vent connection in the back that can take a hold of things and keep the basket from spinning. If you cannot find the object in either area, the last resort would be to split the tub which is a whole other post.
Interesting how a foreign object gets in between the two dubs. Try taking off the cover of the dub, lift unit and turn it up side down. Any loose object should fall. If not you need to take agitator off to take inner tub off and find your culprits.
Hey Narapni,
Please note, this is a front load washer and as such, does not have an agitator. Also, attempting to turn any top load washer over is most likely going to result in the tub separating from the suspension system. Not what I would recommend.
