Frank
Installed a new belt and unit will not drain. Found alot of burnt belt under prior to changing belt. When tested it spun fine, but under actual load washed real slow and will not drain, jus clicks. Is the belt supposed to pivot freely on the motor mounts or? I do not know if the unit is unde warranty and I can not find the papers. It is 10 months old.
