Freezer defrosts and refrigerator warms
I have a Frigidaire side by side that is 9 years old. It will randomly defrost the freezer and then refreeze. Then the refrigerator will get warm after the freezer defrosts. Please Help
A model number may help others help you.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Frigidaire model # FFSS2614QE
I unplugged it and let it sit for few minutes and then plugged back it in and freezer and refrigerator started working again. I an under the assumption that something is going out and unplugging it will only work so long. Please Help.
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/808662201.pdf
This model number does not come up on AppliancePartsPros though I am sure that they will have parts for it.
Sounds like a control board problem but I would go through the diagnostics to see if anything else pops up.
If all OK then I would replace the board.
I am assuming that there are no other symptoms (clicking etc.)
