Freezer door not sealing
The gasket on the top right of my Kenmore Freezer is not sealing from the right hand corner to the left for about 4-6 inches. It does not appear to be compressed or worn out. Is there an adjustment to make the door close more tightly? Your help is greatly appreciated.
Steve,
Make sure the door is not twisted.
Gene - could you tell me what you mean by that and how i could correct it?
Thanks.
steve
Steve,
Usually refrigerator door consists of two parts: outer door and inner door. They are connected each to other with a screws around which are holding door gasket as well. If you loose these screws and then tight them back, they can create unneeded tension causing the door to twist and the door gasket not to seal properly. You may have to pull the door off, lay it down on a flat surface, loosen the screws and re-align.
