Freezer Door won't seal completely
My freezer door all of the sudden will not seal completely on the top.I took the gasket off and flipped it over hoping that would work but it did not. Everything is staying frozen but there are water droplets freezing on the roof of the freezer. It seemed that it was sagging on the opposite side of the hinge so I tried adding another plastic washer hoping that would help but it also did not work. I don’t think I need a new door gasket but I don’t know what to try next. Anyone have any suggestions? Thanks!
You can try to adjust the door gasket, carefully heating it up with a hair dryer.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170334
