This is a side by side freezer/refrigerator. The freezer door pops open when the refrigerator door is closed. The door only opens a little but it is enough to begin defrosting the freezer. If I push on the freezer door after I close the fridge door, it will seal and remain sealed until someone shuts the fridge again. With three kids, someone is always opening the fridge. Thanks for the help.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=GD5LHGXKQ01
Check that the unit is level side to side.
Check that the unit is level front to back or leaning slightly to the back.
Check the door cams item 12 in section 02 also the cam it rides on item 54 in section 01.
The door weight holds the door closed as it is on the down slope of the cam when closed.
