I noticed last night that the freezer seemed a bit warm. In the morning it was only a fridge and the fan in the freezer section is not running at all.I have cleaned the condensor coil and the compressor is running and the condensor fan is running.HELP I HAVE HOT BEER
I would pull the freezer fan motor and plug it in the wall outlet. If blown, I would order a new one. You can order the GE one AP2071867 and pay a high price, or order a SM999 universal replacement at 1/2 price and a better motor that rarely fails. You will have to splice the wires and add end bell rubber bushings to firm it up on the mounts. You can call this parts site to confirm a good replacement. I use this motor in virtually all my replacements.
I was able to finally get it apart to get to the motor and simply found where 1 of the termonals hot broken loose and was able to put it back. Thanks again for your help
