Freezer Fine -Refridge too cold
Freezer is at the proper temp.(0 Degrees) . Fridge is too cold.(32-33 degrees) Fridge temp is set to be 40 degrees. Please help.
adjust the fridg temperature controls up and down. Can you hear the damper door open, then close. If not, you might have a stuck open damper door.
Sorry for the delay getting back to you, I have been out of traveling and have not been able to check the damper until today. It was indeed stuck open. When wiggled the connector it closed. I took the connector apart and cleaned the contacts and am testing it now. Thank you for the help.
Ordered new damper control assembly. It came over night. Installed it and cured the problem. Thank you for the help.
