Ice builds on floor of freezer then water spills on to floor. Freezer on bottom (pull out draw). Pulled away from wall vaccumed, replaced broken rear wheel with 1/4 wood shim. Looked at drain tube after removing rear panel seemed ok. Still leaks
Related topics
freezer door leak | 1 | 994 | January 5, 2009 | |
freezer ice buildup on bottom of floor | 3 | 2022 | July 26, 2012 | |
Freezer ice on floor build up | 3 | 988 | October 8, 2009 | |
water on floor | 1 | 1746 | August 19, 2012 | |
Water leaking on floor | 2 | 1799 | June 27, 2010 |
