Freezer is acting as our fridge
Fridge is not cooling anymore, its luke warm, and the freezer is as cold as a fridge should be. There is ice building up, as we pulled the plug to restart it. We vacuumed the motor for dust, but not sure what the prob., could be… Thermostat??? Motherboard??? What tests can we run…??? Thanks a bunch!!
sounds as if you have a defrost problem, it may the control board which is at back of fridge behind cover
